Preprocessing
Preprocessing
In ball and socket joint analysis with friction coefficient as 0.3, I got this warning
    • Mukka_Srikanth
      In my project while doing fatigue analysis of ball and socket joint for hip implant,
    • Bhargava Sista
      High friction (typically coeff. of friction higher than 0.2) between surfaces can make the stiffness matrix unsymmetric. Sometimes, such cases may face convergence issues in which case using an unsymmetric Newton-Rapshon solver is helpful. In your case, if you did not run into any convergence issues and have a solution (all green check marks on model tree), then you may ignore this message. If you run into convergence issues, then changing the Newton-Raphson option (Analysis Settings --> Nonlinear Controls --> Newton-Raphson Options) to Unsymmetric could be helpful.n
    • Mukka_Srikanth
      Yeah it was helpful...thank you for detail answern
  • The topic ‘In ball and socket joint analysis with friction coefficient as 0.3, I got this warning’ is closed to new replies.
