January 11, 2022 at 12:27 pm
afshiin.a
SubscriberHello, I want to calculate the impulse response of the microring resonator using Lumerical. How is this down?
It should be noted that I obtained the impulse response through the formula of the microring resonator, but I want to use the software to obtain the impulse response of the microring resonator, and I see its result.
Thank you!! -
January 11, 2022 at 7:34 pm
Guilin Sun
Ansys EmployeeThis same question has been replied in another post. You can simply add a time monitor at the output waveguide center. Later on, please only post the same question once, at one forum. -
January 11, 2022 at 7:56 pm
afshiin.a
SubscriberThank you so much, can you more explain this method? I don't know how to define the impulse in the source.?. -
January 11, 2022 at 9:28 pm
Guilin Sun
Ansys EmployeeThe source uses its own pulse. the result from the time monitor is the system's impulse. Please just try and see if you get something. -
January 11, 2022 at 9:56 pm
afshiin.a
SubscriberOkay I do I have a question: Now, in the source settings, do I have to set the start and end wavelengths to one? In other words, should be zero the span? For example, if I want to apply impulse at a wavelength of 1550 nm, should the span be zero?
Thank you ? -
January 12, 2022 at 5:34 pm
Guilin Sun
Ansys EmployeeFDTD is a time-domain algorithm; using Fourier Transform, you can get broadband result in one simulation;
Even through you can set the start and stop wavelengths the same, such as 1550nm, the actual source is still a pulse, meaning a broadband signal. Ansys Insight: FDTD 初学者: 为什么设置了单色光源,监视器却仍然记录了多波长的结果
Usually it is not necessary to use single wavelength, since it is sinusoidal, you do not need its time-domain information. But if you really want, you can create your own source signal, please refer https://support.lumerical.com/hc/en-us/articles/360041722614-4-level-2-electron-material-model
Viewing 5 reply threads
- The topic ‘Impulse response of microring resonator’ is closed to new replies.
1675
1386
1243
