December 2, 2019 at 8:34 pm
Hiwa Ghaffari
SubscriberI'm doing a simulation in Explicit Dynamics in workbench and I want to import stress data from the results of another explicit dynamics analysis.
I exported stress results in text format by right clicking on "Normal stress" icon, then opened the text file in Excel and saved it as a .csv file. Then, I did the settings of "External Data system" as it can be see in the picture, and loaded the .csv file in it. Afterwards, in the Explicit Dynamics system I right clicked on "Imported Pressure" icon and chose "Import Load". But I got this error "The data in worksheet is invalid, Please correct before proceeding to import". Can you please help me?
December 3, 2019 at 2:11 pm
Aniket Chavan
Forum ModeratorFirstly, try to export node data with node coordinates along with the node IDs.
For this change following option from Tools>Option
And check the data type, it should be node ID instead of element ID (If you are sure that the node IDs in newer mesh are the same as older one).
or else import them using node coordinates.
-Aniket
December 3, 2019 at 6:44 pm
December 5, 2019 at 2:26 pm
Aniket Chavan
Forum Moderatorsorry, It seems like with explicit dynamics only external pressure is supported as per the help doc.
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/wb_sim/ds_imported_loads.html
-Aniket
December 5, 2019 at 8:52 pm
Hiwa Ghaffari
SubscriberThank you for your great help. But another question comes up: Can I use Transient Structural system instead of Explicit Dynamics? My analysis should be done in a 0.00001 second step time.
- The topic ‘Importing stress data into a new analysis’ is closed to new replies.
5664
1890
1419
1304
