Importing Mechanical APDL model into ANSYS Workbench
    • Vishal Ganore
      Can a Mechanical APDL model be imported into ANSYS Workbench?
    • Arun Kumar
      Yes. Workbench can read a MAPDL archived coded database file (cdb file). A cdb file can be written from within MAPDL using the CDWRITE command. You should use the db only option to save only the FE data. You do not want to save the solid model, because Workbench cannot read the MAPDL solid model or cad data. If the model is an assembly, you could create one cdb file for the whole model or multiple .cdb files for each sub-assembly. Note: Workbench cannot import a MAPDL binary database (db) file. It can only read the ASCII .cdb file.
    • pradeep
      can anyone say me the steps to follow to transfer the solved APDL data to workbench , i have done it in with external model then linking it to mechanical model and transferred it to static structural .
      but i am unable to do it for transient case is there any other imports that i am missing..
    • Ashish Khemka
      You may follow the steps by Arun or the documentation should have the steps required.
      Ashish Khemka
  • The topic ‘Importing Mechanical APDL model into ANSYS Workbench’ is closed to new replies.
