July 7, 2021 at 2:00 pm
HAIMANTI
SubscriberI have designed a Maxwell 2D model for a three-phase induction motor. I want to check the performance of IM when its stator is connected to a three-phase two-level inverter, and the inverter is operating in 180 degree square wave conduction mode. I have designed a Max circuit using voltage- controlled switch and pulses, and operated it in 180 degree conduction mode. I am exporting netlist, and importing the netlist in Maxwell 2D. When I hit 'Analyse all', the error message "the circuit consists of independent subcircuit or invalid current source set ansys error" is shown. Please help. The screenshot of the three-phase two level inverter and the error message are attached.
July 12, 2021 at 3:48 pmHDLI
Ansys Employee-
October 2, 2023 at 6:49 am
mehmed çelebi
SubscriberHi
I have some problems about one phase inverter in max circuit. Colud you please help me.
Thanks.Â
July 13, 2021 at 3:51 amHAIMANTI
SubscriberThanks a lot. The problem is solved.
Viewing 2 reply threads- The topic ‘Importing Max circuit in Maxwell 2D’ is closed to new replies.
5649
1885
1404
1303
