March 21, 2019 at 11:02 am
March 22, 2019 at 1:44 am
peteroznewman
SubscriberYou can select a face on the solid body, use Copy and Paste and you will have a surface as well as the solid. When you have done this for each face of the solid, you can delete the solid.
March 22, 2019 at 4:50 am
Keyur Kanade
Ansys Employeeselect all necessary surfaces. then use ctrl + c and ctrl + v to copy these faces.
once you copy necessary faces, you can delete original one. if some faces are missing, you can create those in spaceclaim.Â
https://www.youtube.com/watch?v=UJ9v7nc4LYE
- The topic ‘Importing Geometry (from Solidworks)’ is closed to new replies.
