March 15, 2023 at 6:34 am
Madhu Kumar Muniseetappa
SubscriberHi team,
We have solve parent model of case 1. That case 1 results are used as Cut boundary constraint for Sub model.
Same way we have one more parent model case2. That case 2 results are used as Cut boundary constraint for Same sub model (on same surafces as case 1). So if we try to solve it is not solving and if we check dat one of the constraint is reading properly.
Doubt is can we import two Cut BC s for same sub model.
Please we need help on this issue.
March 16, 2023 at 3:37 pm
ashish.khemka
Forum ModeratorHi Madhu,
Please use only one set of Cut BCs on the surface from one global model.
Ashish Khemka
- The topic ‘Importing Cut boundary Constraint from Full model (Parent ) to Submodel’ is closed to new replies.
