March 27, 2019 at 4:15 pm
Sam Fares
SubscriberHello,
how do i import a geometry, Analysis Settings, or setup from another ansys mech file?
Thanks,
Sam
March 27, 2019 at 5:12 pm
sathya
SubscriberHi To write the Mechanical APDL application input file:
Highlight the Solution object folder in the tree. From the Main Menus, choose Tools> Write Input File. In the Save As dialog box, specify a location and name for the input file. -
March 27, 2019 at 5:13 pm
sathya
SubscriberHi To export geometry, you can save it in DM with desired format and export -
March 27, 2019 at 6:16 pm
Sam Fares
SubscriberThank you Sathya!
 i use workbench. how can i import for example my Analysis setting for nonlinear analysis, results from one ansys file to another ansys file? i am trying to avoid duplicating the work.
Thanks,Â
Sam
April 1, 2019 at 1:09 pm
sathya
To read the Mechanical APDL application result files:
From the Main Menus, choose Tools> Read Result Files.
Browse to the folder that contains the Mechanical APDL application result files and click Open.
In the dialog box that follows, select the unit system, then click OK.
Viewing 4 reply threads
- The topic ‘Importing a geometry or Analysis Settings ,setup from another ansys file’ is closed to new replies.
