Import meshed geometry from hypermesh
    • damianoaquila
      Hi, i have a problem with the hypermesh to ansys exportation. I've meshed an exaust with hypermesh and i want to study it on Ansys fluent. I've tried to export the exaust in "user profile Ansys" but it can not be used in ansys fluent.
      Can someone explain me the iter to export the mesh and import it in Ansys fluent?
      Best regards,
      D.P.
    • Keyur Kanade
      i am not sure if student version can import from hypermesh.
      please try to export .msh or .cas file from hypermesh. then you can read .msh or .cas file in fluent.
      Please post the questions in appropriate category. Moving this question to other category to get better response.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
  • The topic ‘Import meshed geometry from hypermesh’ is closed to new replies.
