December 29, 2023 at 12:57 pm
Muhammad Hamza Arshad Khan
SubscriberHello, Â
I have a human bone geometry which I meshed on mimics and then imported it to ansys. The mesh imported successfully but I also mapped anisotropic material properties of bone on mimics but I cannot import these properties on ansys mechanical. Mimics clearly states that these files are being exported for ansys. Mimics gave me a .txt file for material properties which I cannot import in ansys. The text file contain data in this format:
I also tried using apdl command in ansys mechanical according to a solution I read online but it didnt work too.
 Would someone kindly guide me how to import these material properties in ansys using this .txt file.
Thanks in advance,
January 2, 2024 at 10:47 am
Ashish Khemka
Forum ModeratorHi,
It looks that you have created same post here: Import Material Properties in .txt file to ansys mechanical
I will close this topic.
Ashish Khemka
- The topic ‘Import material properties from .txt file into ansys mechanical’ is closed to new replies.
6495
