January 6, 2026 at 3:23 pm
cesarj.95plus
SubscriberDear support,
I am trying to simulate a simple 2D case of a vertical wind turbine. The first step is to import such geometry into Fluent meshing but I am strugling with it at this stage. As you can see I have the geometry imported in space claim (it was generated in an external CAD tool and imported as .stp) and my goal is to have the same naming for each face and edge in the Fluen session so I can know which element I am meshing and where to apply the right BCs. However not only the names aren't imported by also there is an error with more than one meshing parts identified. All the surfaces are in contact (no gaps) and the curves are the edges of each surface. Could someone provide support with respect this issue?
January 7, 2026 at 1:45 pm
B D
Ansys EmployeeHello,
Neutral file format like step do not preseve the Name selection information. Please use native CAD file format such as .scdoc/ .dsco.
January 7, 2026 at 2:09 pm
Anilkumar
Thanks for contacting Ansys Forum support.
Looking at the shared snap the Names given on the geometry are separate curves entities in SpaceClaim which can not be transferred as is. Also, I see that you have 2 main fluid regions, naming MRF and Main Fluid.
Please follow below steps:
1) Create separate component for the Fluid regions. Select those 2 bodies from structure tree and move to new component.
2) Keep the BOI bodies in separate component or let it be outside of Fluid bodies components.
3) Hide the BOI bodies and make sure only 2 fluid regions are visible. perform share topology from Workbench > Share tab.
4) Then go to Groups tab > and select those desired edges from GUI where you want to add named selections like inlet, airfoil, wall upper etc. those NS will be transferred to Fluent meshing.
5) Then you should be able to get the desired meshing operations working fine.
Anil
January 9, 2026 at 5:18 pm
cesarj.95plus
SubscriberThanks for the replies, however that would mean to shift completely my CAD strategy to adapt to Fluent's inputs. In my case using SpaceClaim will not be possible... Which would be the best approach to preserve faces and edges naming from a CATIA part into Fluent Meshing?Â
January 9, 2026 at 6:02 pm
Anilkumar
Ansys EmployeeHi,
Thank you for reaching back.
You can import the named selections(publications or attributes) from CATIA file to Ansys. To import this information from CATIA files(catpart) you need to have cad interface.
Please look for the short video on this capability. Google CATIA to Ansys workbench cad transfer and it has AnsysHowTo video on parameters and named selections import procedure.
Anil
January 9, 2026 at 6:20 pm
Anilkumar
Ansys EmployeeOne more thing to remember is the named selections needs to be on the surface/face boundary edges and not separate edge entities. Since we can't take separate edges entities to meshing. They need to be associated with surface.
Also you need to define the share topology between fluid regions in 2d to get connected region with conformal mesh.
Thank you.
4858
1587
1386
1242
