TAGGED: ansys-maxwell, electromagnetics, magnetic-field, magnetics
August 9, 2023 at 2:01 pm
Joshua Igl
SubscriberHello,Â
I am new to Ansys and for my current project I am wondering if there is any possibility to implement a user defined magnetic field in Ansys to do further simulation with.
For my Application, let's say I have a matrix of Tesla-Values which i want to transfer into Ansys and maybe interpolate values in between the given ones. I want to use this magnetic field to simulate the effects it is having on other objects. Is there any way this is possible?
I was able to create nearly homogenic B-Fields by creating Helmholtz-Coils or a simple long coil with currents in Maxwell. But with this approach I can't create the exact representation of the magnetic field I want to achieve and work with.
I would be grateful for any help, i hope this is the right channel for my question since this is my first post.Â
Thank you,Â
Joshua
August 10, 2023 at 4:40 pm
GLUO
Ansys EmployeeHello,
The Helmholtz-Coils and PMs are used to define magnetic field excitations. Maxwell cannot take specific field data as the input. Please check LS-DYNA, it should be able to do this.
GL
August 14, 2023 at 10:13 am
Joshua Igl
SubscriberDo you know any Details on how to import such field data in LS-DYNA? I did some research and could not quite find an answer.. I only found out that it seems possible to import this kind of data in Fluent.
Thank you in advance,Â
Joshua
August 31, 2023 at 9:29 pm
GLUO
Ansys EmployeeHi Joshua,
I only know there were some people did similar work in LS-DYNA, but not the details. Did you find out how to do it? If not, please post the question on LS-DYNA /Fluent block. Â
Thanks,
GL
September 4, 2023 at 7:28 am
Joshua Igl
SubscriberHi Gluo,
Thanks for your help, I did not find a way to do it yet. I posted the question on the LS-DYNA Channel.
Joshua
August 11, 2023 at 8:44 am
Joshua Igl
SubscriberThank you for your recommendation! I will take a look into LS-DYNA.
August 14, 2023 at 10:12 am
Joshua Igl
SubscriberÂ
@GLUO Do you know any Details on how to import such field data in LS-DYNA? I did some research and could not quite find an answer.. I only found out that it seems possible to import this kind of data in Fluent.
Joshua
Edit: sorry I missed the reply feature..Â
- The topic ‘Implement a user defined Magnetic Field to do further Simulation with’ is closed to new replies.
5654
1885
1404
1303
