September 26, 2020 at 12:32 pm
PrabhuManickam
SubscriberHi,nI want to run a Impact analysis, 120 N of hammering load acting on a Aluminium clamp for 5 to 10 times then want to check the deformation and stress of the Clamp.n -
September 27, 2020 at 6:19 pm
peteroznewman
SubscriberRead this discussion.nHi all.I have to simulate an impact of a pendulum on a test piece. Normally, it wouldn't have any problem, but the impact has to be repeated. That is, the pendulum strikes the specimen, returns to the initial position, and strikes again. This process is repeated for X times. Which tool can I use to perform the test? Explicit dynamics? Static structural? I really don't know...Thank you very much./forum/discussion/20408/which-tool-should-i-use
- The topic ‘Impact Load Analysis’ is closed to new replies.
