July 16, 2020 at 10:50 pm
helen.durand
SubscriberHello,
I have been running a Fluent simulation on a HPC system. When I click on 'check' under the parallel menu in Fluent, I get the these warnings:
Looking at the other printouts under the parallel menu in Fluent, I see some high latencies and low bandwidths between certain pairs of nodes.
Is this a problem with the settings in Fluent (such as perhaps in the way in which Metis is partitioning the elements among the processes) or is this a problem related to the HPC system on which I am running the simulation?
Also, does anyone have any advise on how to address this issue?
Any help would be appreciated. Thank you!
Below I have included the active partition printout:
July 17, 2020 at 8:57 am
Amine Ben Hadj Ali
Ansys EmployeeI will rather use smaller number of process having an aim to have 30K for each partition.Â
Please aslo check Latency and Bandwidth.
- The topic ‘Imbalanced loads on HPC cluster’ is closed to new replies.
3049
971
900
858
792
