January 5, 2026 at 1:48 pm
awoneye.segun
SubscriberI actually need assistance on how to go about it
January 5, 2026 at 3:09 pm
Forum ModeratorIs there a flowing fluid, or is it "solid" rock?
January 7, 2026 at 2:38 pm
awoneye.segun
SubscriberThe bed is made up of granite with air as the working fluid flowing through it.
I intend simulating a cubical and cylindrical rock bed.
January 7, 2026 at 2:48 pm
Forum ModeratorOK, given granite is what we'd typically consider as an impermeable solid I assume pressure drop is going to be high. Do you have permeability data or are you wanting to model the pore structure?
January 7, 2026 at 3:05 pm
awoneye.segun
SubscriberI intend varying the permeability/porosity. I will want to private chat you so that we can discuss it extensively. And to see how the porosity affects pressure drop and heat transfer through the medium.
January 7, 2026 at 3:09 pm
Forum ModeratorI can only respond via the Forum: it's one of the Rules from Legal to allow staff to answer. If you've got a commercial licence you can contact the licence provider for support - I don't know where (or who) you are so it could be Ansys directly or a Channel.
January 7, 2026 at 3:14 pm
awoneye.segun
SubscriberI need a guide from developing the geometry to carrying out the actual simulation. I'm a beginner in Ansys, and I know it will be a bit difficult.
Though, I understand what the expected results will be from a practical angle. I actually needed a tutor.
January 7, 2026 at 3:20 pm
Forum ModeratorWhich I can't provide via the Forum. I can point you at the various Learning resources and answer questions (to as high a level as I'm permitted).
The starting point from a modelling project is to decide what you need to know from the results, and also what you can afford (time and cpu) to spend. So, geometry could be a porous media, or it could come from micro-CT. That then guides the mesh and solver set up.
January 7, 2026 at 3:38 pm
awoneye.segun
SubscriberOk. I really appreciate. I want to be able to first generate the geometry for a cuboid and cylindrical bed.
If you can help me with materials to achieve that. I will be very grateful
January 7, 2026 at 3:58 pm
Forum ModeratorLook in Learning (left side menu here). You can create geometry in Discovery or in a CAD tool of your choice to transfer to Discovery. So, have a look in the Geometry, Meshing, CFD and Fluent courses. There are also tutorials in https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/main_page.html?hl=f under the products (Discovery, Meshing and Fluent). For Meshing you have options, I'd suggest Fluent Meshing as it's more useful in the long term.
4823
1587
1386
1242
