August 13, 2024 at 6:54 pm
August 19, 2024 at 1:28 pm
Timos
Ansys EmployeeHello, to create a cross-section of a 3D object in ANSYS, you should use the Modeler > Surface > Section command. This command allows you to create cross sections of 3D objects on the XY, YZ, or XZ plane, resulting in 2D closed polyline objects. Here are the steps you should follow:
1. Set the working coordinate system you want to use for the cross-section plane.
2. Select the object from which you want to create a cross section.
3. From the menu bar, click Modeler > Surface > Section.
Make sure that the object you are trying to create a cross-section from is a 3D object, as the command is intended for this purpose. If you continue to experience issues, it may be beneficial to consult the ANSYS documentation or support for further assistance with the specific error message you are encountering. -
August 19, 2024 at 11:03 pm
sojoseph
SubscriberThank you.
August 22, 2024 at 8:33 pm
sojoseph
Subscriber-
August 27, 2024 at 1:10 pm
MirandaH
Ansys EmployeeHello, what is the current status of the simulation? Is it meshing or solving?
August 27, 2024 at 5:21 pm
sojoseph
SubscriberMeshing. It takes forever to mesh.
August 27, 2024 at 5:23 pm
sojoseph
SubscriberHow possible can i reduce all this process and solving the system in one or two hours?
August 27, 2024 at 5:42 pm
MirandaH
Ansys EmployeeTo speed up meshing in Maxwell transient simulation, you can consider the following techniques:
1. Simplify the model where possible to reduce the complexity of the mesh. This can be done by hiding objects that are not essential for the simulation or by combining bodies into multibody parts even if they are not touching, as this will reduce the number of parts to be processed.Â2. Use advanced mesh operations techniques to improve the mesh quality. For example, in areas where the mesh creates bad quality tetrahedra, you can apply specific mesh operations to refine the mesh and improve the element quality
3. Optimize the initial mesh settings. For instance, in the General Tab of the Initial Mesh Settings, you can check TAU and move the slider one step to the right to potentially improve the meshing process -
August 27, 2024 at 6:38 pm
sojoseph
SubscriberÂ
I’m designing the system with Ansys maxwell UDP, currrently i am having a zero torque. My question is how do i define my power so that i can have positive torque?
August 28, 2024 at 7:15 pm
MirandaH
Ansys EmployeeTo define power in Maxwell for achieving positive torque, you should consider the correct setup for the geometry, the excitation, the boundry condition and the the mechanical transient setup. You can open up a RMxprt example, create a Maxwell model and use it as a reference.
August 28, 2024 at 3:19 am
August 28, 2024 at 7:17 pm
MirandaH
Ansys EmployeeTo reduce the edges in meshing:
1. Simplify the model where possible to reduce the complexity of the mesh.Â2. Use advanced mesh operations techniques to improve the mesh quality.Â
August 28, 2024 at 7:21 pm
sojoseph
SubscriberI'm using this software for the first time and i can't reallly comprehend what you mean here?
is there a pdf that explains what you're saying?
August 28, 2024 at 7:22 pm
sojoseph
SubscriberHow do I simplify my model?
August 28, 2024 at 7:37 pm
sojoseph
SubscriberCan i share my model design?
so that you can be able to guide me properly.Â
September 5, 2024 at 2:41 pm
MirandaH
Ansys EmployeeUnfortunately, this question is beyond the scope for Ansys employees to answer on a public forum as it requires to verify the model. Ansys employees cannot access any attachments on the forum. We encourage other participants on the forum to help with your problem.
If you have access to Ansys Service Requests, please raise a service request.
September 5, 2024 at 8:16 am
sojoseph
SubscriberSource setup error, possible reasons are 1) The solved region is not singly connected. If any circle in the solved region can not be freely shrunk to a point, then solved region is not regarded as singly connected. 2) The master and slave boundaries are separated. For this case, “Zero Tangential H Field?boundary condition need to be assigned on one boundary connecting master and slave boundaries.
how can the above error be solved?
September 5, 2024 at 2:44 pm
MirandaH
Ansys Employeeplease check the region geometry and boundry conditions for the source setup error.
September 5, 2024 at 5:30 pm
sojoseph
SubscriberI have been on this for five days checkng the boundry conditions. same error exist
September 7, 2024 at 8:10 pm
sojoseph
SubscriberIs there a way whereby i can simulate my model to run in different RPMs (200-1200) to see the using optimetrics?
I want to see the torque generated by running it with different RPMs.Â
September 10, 2024 at 1:08 pm
MirandaH
Ansys EmployeeYes, you can use a variable as the rotating speed in motion setup, and setup an optimtrics table.
September 11, 2024 at 7:49 am
sojoseph
SubscriberThank you so much. I have done that but i have a negative torque instead of positive?
what could be wrong and how can i fix it?
September 11, 2024 at 1:27 pm
MirandaH
Ansys Employeeplease check excitation: value and direction, motion: rotation direction and rotating axis.
September 13, 2024 at 5:43 pm
sojoseph
Subscriber"Memory allocation error"
how can i clear this error message? i currently use of laptop of 32G ram, 512G rom.
September 14, 2024 at 9:40 pm
sojoseph
SubscriberI have three questions.
- How can i define the machine parameters in maxwell 3D such as apparent power, voltage and and the likes as defined using RMxprt?
- Apart from motion setup, how can i defined the speed of the machine whereby i can have different plots for different speed in maxwell 3D?
- How can i plot the machine efficiency?
September 14, 2024 at 10:35 pm
sojoseph
SubscriberCalculation of Inductance and Resistance of a Coil
I'm trying to calculate the inductance and the resistance of the whole winding. Is it possible to get this through magnetostatic solver or eddy current solver will give the P_Ohmic and I_peak.Â
how can i get the following aforementioned?
October 19, 2024 at 11:24 am
October 19, 2024 at 11:26 am
5969
1307
