September 11, 2023 at 6:05 pm
zhabib2
SubscriberHello,Â
I was trying to model a tank partially filled with water to impact. When I tried the ICFD fluid model separately, the models works fine, but when I try to couple them, the model doesn't coverge and after several iterations it says it has some intersecting faces, which should not happen. I tried to add initial velocity to the solid using *INITIAL_VELOCITY_GENERATION and to the fluid using *ICFD_INITIAL. When i remove the *ICFD_INITIAL card, the FSI model runs fine, but the fluid starts at a 0 velocity. I want the whole fluid volume to have an initial velocity same to the solid container.
Can anyone please suggest how should I try to solve this issue?
I am adding my keywords (with out the mesh) below:Â
Solid
*CONTROL_CONTACT
$  slsfac   rwpnal   islchk   shlthk   penopt   thkchg   orien
    0.1    1.0     1     0     1     0     1     0
$  usrstr   usrfrc   nsbcs   interm   xpene   ssthk    ecdt  tiedprj
     0     0     0     0    4.0     1     1     0
$#  sfric   dfric    edc    vfc     th   th_sf   pen_sf   ptscl
    0.0    0.0    0.0    0.0    0.0    0.0    0.0    1.0
$#  ignore   frceng  skiprwg   outseg  spotstp  spotdel  spothin
     0     0     0     0     0     0    0.0
$#   isym   nserod   rwgaps   rwgdth   rwksf    icov   swradf   ithoff
     0     0     1    0.0    1.0     0    0.0     0
$#  shledg   pstiff   ithcnt   tdcnof   ftall   unused   shltrw   igactc
     0     0     0     0     0         0.0     0
*CONTROL_ENERGY
$#   hgen    rwen   slnten   rylen   irgen   maten   drlen   disen
     2     2     2     1     2     1     1     1
*CONTROL_IMPLICIT_AUTO
$#  iauto   iteopt   itewin   dtmin   dtmax   dtexp   kfail   kcycle
     1    100     20    0.0    -700    0.0     0     0
*CONTROL_IMPLICIT_DYNAMICS
$#  imass   gamma    beta   tdybir   tdydth   tdybur   irate   alpha
     1    0.55  0.27563    0.01.00000E281.00000E28     1    0.0
*CONTROL_IMPLICIT_GENERAL
$#  imflag    dt0   imform    nsbs    igs   cnstn    form   zero_v
     1    0.1     2     0     1     0     0     0
*CONTROL_IMPLICIT_SOLUTION
$#  nsolvr   ilimit   maxref   dctol   ectol   rctol   lstol   abstol
    12     11     15   0.001    0.01    0.0    0.01.0000E-20
$#  dnorm   diverg   istif  nlprint   nlnorm  d3itctl   cpchk
     2     1     1     3     2     10     0
$#  arcctl   arcdir   arclen   arcmth   arcdmp   arcpsi   arcalf   arctim
     0     0    0.0     1     2    0.0    0.0    0.0
$#  lsmtd   lsdir    irad    srad    awgt    sred
     5     2    0.0    0.0    0.0    0.0
*CONTROL_OUTPUT
$#  npopt   neecho   nrefup   iaccop   opifs   ipnint   ikedit   iflush
     1     3     0     0    0.0     0    100    5000
*CONTROL_SHELL
$#  wrpang   esort   irnxx   istupd   theory    bwc   miter    proj
   20.0     1     -1     0     2     1     1     1
$# rotascl   intgrd   lamsht   cstyp6   thshel
    1.0     0     0     1     0
$# psstupd  sidt4tu   cntco   itsflg   irquad   w-mode  stretch    icrq
     0     0     0     0     2    0.0    0.0     0
$#  nfail1   nfail4  psnfail   keepcs   delfr  drcpsid   drcprm  intperr
     0     0     0     0     0     0    1.0     0
*CONTROL_TERMINATION
$#  endtim   endcyc   dtmin   endeng   endmas   nosol
   100.0     0    0.0    0.01.000000E8     0
*DATABASE_GLSTAT
$#    dt   binary    lcur   ioopt
    0.1     0     0     1
*DATABASE_MATSUM
    0.1     0     0     1
*DATABASE_NODOUT
$#    dt   binary    lcur   ioopt  option1  option2
   0.01     0     0     1    0.0     0
*DATABASE_RCFORC
    0.1     0     0     1
*DATABASE_BINARY_D3PLOT
$#    dt    lcdt    beam   npltc   psetid
    2.0     0     0     0     0
*DATABASE_EXTENT_BINARY
$#  neiph   neips   maxint   strflg   sigflg   epsflg   rltflg   engflg
     0     0     3     0     2     2     2     2
$#  cmpflg   ieverp   beamip   dcomp    shge   stssz   n3thdt  ialemat
     0     1     0     1     1     1     2     1
*MAT_PIECEWISE_LINEAR_PLASTICITY
$#   mid     ro     e     pr    sigy    etan    fail    tdel
    1007.86000E-6   200.0    0.28   0.326    0.01.00000E21    0.0
$#    c     p    lcss    lcsr     vp
   40.0    5.0     0     0    1.0
$ plastic stress strain curve
$# Â Â eps1 Â Â Â eps2 Â Â Â eps3 Â Â Â eps4 Â Â Â eps5 Â Â Â eps6 Â Â Â eps7 Â Â Â eps8
    0.0   0.0152   0.0226   0.0407   0.0691   0.0983   0.1345   0.7093
$# Â Â es1 Â Â Â es2 Â Â Â es3 Â Â Â es4 Â Â Â es5 Â Â Â es6 Â Â Â es7 Â Â Â es8
   0.326   0.328   0.3788   0.4414   0.497    0.53   0.5557   0.7604
*PART
$# Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â title
Container shell
$#   pid   secid    mid   eosid    hgid    grav   adpopt    tmid
    100    100    100     0     0     0     0     0
*SECTION_SHELL
$#  secid   elform    shrf    nip   propt  qr/irid   icomp   setyp
    100     2    1.0     5    1.0     0     0     1
$ Â Â Â t1 Â Â Â Â t2 Â Â Â Â t3 Â Â Â Â t4 Â Â Â nloc
$#    t1     t2     t3     t4    nloc   marea    idof   edgset
    3.0    3.0    3.0    3.0    0.0    0.0    0.0     0
$#    id    styp   omega     vx     vy     vz   ivatn    icid
    100     2    0.0    20.0    0.0    0.0     0     0
$#    xc     yc     zc     nx     ny     nz   phase   irigid
    0.0    0.0    0.0    0.0    0.0    0.0     0     0
*DEFINE_CURVE
$#   lcid    sidr    sfa    sfo    offa    offo   dattyp   lcint
    700     0    1.0    1.0    0.0    0.0     0     0
$# Â Â Â Â Â Â Â Â a1 Â Â Â Â Â Â Â Â Â o1
         0.0         0.1
         1.0         0.1
        100.0         0.1
*RIGIDWALL_PLANAR_ID
$#    id                                 title
     1                                   Â
$#   nsid   nsidex   boxid   offset   birth   death   rwksf
     0     0     0    0.0    0.01.00000E20    1.0
$#    xt     yt     zt     xh     yh     zh    fric    wvel
  1100.0    0.0    0.0   1000.0   100.0    0.0    0.0    0.0$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Fluid and FSI
*ICFD_BOUNDARY_FSI
$# Â Â pid
     1
     2
*ICFD_CONTROL_FSI
$#   owc     bt     dt    idc   lcidsf   xproj
     0    0.01.00000E28    0.25     0     0
$# Â Â nsub
     0*ICFD_INITIAL
$#   pid     vx     vy     vz     t     p        dfunc
     0    20.0    0.0    0.0    0.0    0.0     0     0
*LOAD_BODY_Z
$#   lcid     sf   lciddr     xc     yc     zc    cid
     2    1.0     0    0.0    0.0    0.0     0
*DEFINE_CURVE_TITLE
Velocity imposed
     1     0   100.0    20.0    0.0    0.0     0     0
         0.0         1.0
        10.0         1.0
*DEFINE_CURVE_TITLE
Gravity force
     2     0    1.0  0.00981    0.0    0.0     0     0
         0.0         1.0
       10000.0         1.0
*INCLUDE
ICFD_mesh.k
*ICFD_BOUNDARY_NONSLIP
$# Â Â pid
     1
$# Â Â pid
     2
*ICFD_CONTROL_TIME
$#   ttm     dt    cfl   lcidsf   dtmin   dtmax   dtinit   tdeath
   100.0    0.0    1.0     01.00000E-91.00000E28    0.01.00000E28
*ICFD_MAT
$#   mid    flg     ro    vis     st  stsflcid     ca
     1     11.00000E-61.00500E-9    0.0     0    0.0
*ICFD_MAT
     2     0    0.0    0.0    0.0     0    0.0
*ICFD_PART_TITLE
Water
$#   pid   secid    mid
     1     1     1
*ICFD_PART_TITLE
Air
$#   pid   secid    mid
     2     1     2
*ICFD_PART_TITLE
Interface
$#   pid   secid    mid
     3     1     1
*ICFD_PART_VOL
$#   pid   secid    mid
    10     1     1
$# Â spid1 Â Â spid2 Â Â spid3 Â Â spid4 Â Â spid5 Â Â spid6 Â Â spid7 Â Â spid8
     1     3     0     0     0     0     0     0
*ICFD_PART_VOL
$#   pid   secid    mid
    20     1     2
     2     3     0     0     0     0     0     0
*ICFD_SECTION
$# Â Â sid
     1
*MESH_INTERF
$# Â volid
    10
$# Â Â pid1 Â Â Â pid2 Â Â Â pid3 Â Â Â pid4 Â Â Â pid5 Â Â Â pid6 Â Â Â pid7 Â Â Â pid8
     3     0     0     0     0     0     0     0
*MESH_VOLUME
$# Â volid
    10
     1     2     0     0     0     0     0     0 -
September 12, 2023 at 4:12 pm
Reno Genest
Ansys EmployeeHello,
Have you checked the iCFD examples on sloshing?
https://www.dynaexamples.com/icfd
https://www.dynaexamples.com/icfd/basics-examples/global_imposed
https://www.dynaexamples.com/icfd/intermediate-examples/slosh2
There is also a course on iCFD on the Ansys Learning Hub (ALH):
https://jam8.sapjam.com/groups/QyHAlhciRCZ0Xt6xKZ2MHi/overview_page/jPMouxqQ2AOP6jVZLBMZCl
Reno.
- The topic ‘ICFD model for sloshing FSI in a container- initial velocity issue’ is closed to new replies.
6750
1324
1087
