July 19, 2024 at 12:23 am
dlrhksxor123
SubscriberI'm trying to do transient simulation using Ansys icepak, but if I set the on and off times to less than 1 micro second in the transient settings in source thermal modeling, the graph reform does not appear in the time graph below. Is the transient working normally?
If the on and off times are set to exceed 1 micro second, the shape is normally visible in the time graph.
July 26, 2024 at 7:56 am
Yannis
Ansys EmployeeHi Gwan Taek Lee,
This looks like a bug. Altough you will not be seeing much difference in the results, we are supporting nano and micro seconds. This looks like an issue with the graph display. I will be escalating this to development, thank you for bringing it to our attention.
Kind regards,
Yannis Skourkeas
- The topic ‘Icepak transient setting (below micro second)’ is closed to new replies.
