December 5, 2018 at 7:00 pm
upot2
SubscriberHello,
I have an issue opening existing files on Icepak 19.0. When I click on 'Existing' to open an an existing Icepak file, I get the error attached in the picture below. I am able to unpack tzr files and open them up on Icepak, however I am unable to load existing files. Since I would need to load existing files to recover previously saved solutions, this is not ideal. Can someone tell me how I go about addressing this issue?
December 5, 2018 at 7:51 pm
ANSYS_MMadore
Forum ModeratorHello,
Can you please check to be sure you are not using C:WindowsTemp for your TEMP or Working directories? It is trying to access that directory as you can see in the first line of the error. You should not use C:Windows for any temp or working directories. You can check the environment variables, or if you right-click on Icepak you can also look at the Properties for the "Start In" directory.
Thank you,
Matt -
December 5, 2018 at 8:01 pm
December 5, 2018 at 8:14 pm
ANSYS_MMadore
Forum ModeratorTo check your environment variables you can open a command prompt and run this command and provide the resulting envout.log file? It will be created in the directory currently displayed in the command prompt prior to the > symbol.
set > envout.log
Thank you,
Matt -
December 5, 2018 at 8:19 pm
upot2
SubscriberHi Matt,
Thanks, I changed the environment variable to the right directory and it works fine.
December 5, 2018 at 8:20 pm
ANSYS_MMadore
Forum ModeratorExcellent, happy to hear it. Have a wonderful day.
Thank you,
Matt -
March 23, 2020 at 6:50 pm
malik.awais19
Hi Matt,
Can you plz share what you did .... coz i have he smae issue but i am getting what MAtt has adviced
- The topic ‘Icepak Installation Error’ is closed to new replies.
4673
1565
1386
1231
