October 2, 2019 at 5:54 pm
lcoolidg
SubscriberICEM CFD 2019 R2 Help Fails and generates the following error:
Couldn't change working directory to "~": No such files of directory
October 2, 2019 at 9:24 pm
tsiriaks
Ansys EmployeeCould you post the screenshot of this ?
It sounds like you point to the local install of help documentations. Did you install help locally (this is separate install than the main software) ?
Otherwise, you can access the online help (need portal login)Â https://ansyshelp.ansys.com
October 2, 2019 at 11:23 pm
October 2, 2019 at 11:27 pm
lcoolidg
SubscriberHere's a screen shot of the error. I expected clicking on help within ICEM to take me to the on line documentation like workbench does in this installation. I did not do a separate install of ICEM locally. Thanks
October 7, 2019 at 10:42 pm
tsiriaks
Ansys EmployeeIf you open CMD Prompt, then issue the following command
"%icemcfd_root194%..commonfileshelpHelpViewerANSYSHelpConfigurationTool.exe"
is it set to online help or local help ?
October 8, 2019 at 5:36 pm
lcoolidg
SubscriberIt is set to online help. This was the default, I did not change it.
 I wanted to emphasize that within ICEM CFD if you select help is locks up the session and your have to close the program. So what ever is coded behind the help button needs to be fixed. Help from workbench functions normally going to web help.
Thanks for your help.
Larry
October 11, 2019 at 4:09 pm
tsiriaks
Ansys EmployeeI can't reproduce the issue.
What if you do File -> Change Working Directory -> Then, specify C:Temp and try launching Help again ?
October 18, 2019 at 6:21 pm
October 18, 2019 at 9:25 pm
tsiriaks
Ansys EmployeeHmm, not sure why it's trying to change working directory to ~
Can you post the output of the 'set' command (no quote ' ')Â from the CMD Prompt ?
October 18, 2019 at 10:14 pm
lcoolidg
October 18, 2019 at 10:22 pm
lcoolidg
Subscribersee attached file set.txt
October 19, 2019 at 12:42 am
tsiriaks
Ansys EmployeeANSYS employee is not allowed to download or open this attachment
Could you post an in-line screenshot of it ?Â
October 19, 2019 at 1:00 am
October 21, 2019 at 5:08 pm
tsiriaks
Ansys EmployeeThe issue is with your HOMEDRIVE and HOMEPATH , which are combined to point to U:
Can you change this to be a local directory ?
If you want to test first if it really helps, you can open CMD Prompt, then issue the following commands
set HOMEDRIVE=C:
set HOMEPATH=temp
"%awp_root194%icemcfdwin64_amdbinicemcfd.bat"
then, launch Help from here.
October 21, 2019 at 5:53 pm
lcoolidg
Subscribertsiriaks:
set HOMEDRIVE=C:
set HOMEPATH=temp
that solved the problem so I edited the "%awp_root194%icemcfdwin64_amdbinicemcfd.bat" and added the above two lines to the bat file.
good job you can close this post as solved
thanks
Larry
October 21, 2019 at 6:08 pm
tsiriaks
Ansys EmployeeHi Larry,
That's good to hear.
Thanks for the confirmation.
Win
- The topic ‘ICEM CFD 2019 R2 Help Fails’ is closed to new replies.
4989
1670
1386
1243
