March 19, 2024 at 2:06 pm
yair.oros
Subscriber -
March 20, 2024 at 5:02 pm
Benjamin Descorps
Ansys EmployeeHello,
Can you explain me in more details what you are trying to do? For example, do you want to connect a graphical panel to your Suite project for simulation purpose or something else?
Thanks,
Benjamin
March 20, 2024 at 7:09 pm
yair.oros
SubscriberHey!,
Yes! that's correct, I wish to connect a grhapical window with a project of suite, i mean may be just a counter that creates a figure that rotates with reference in the counter.Â
I have until the co-simulation, but I Can't remember the part of create a conection between the variables.
Thanks.
Yair
March 26, 2024 at 2:25 pm
Benjamin Descorps
From your Display project, you have to define the plug variables to your graphical objects (example: text to be displayed, integer values):
In your Suite project, you have to add the Display project as reference:
From this point you should be apply to define the mapping between you Suite root operator and the available plugs of your Display specification by using the command "Connect to Graphical Panels" from the contextual menu:
I suggest you to have a quick look to the CruiseControl example as it provides an example of connections to both one Display and one Rapid Prototyper panels.
Hope this helps,
Benjamin
- The topic ‘I wish to know how to make Integration between Suite and Display’ is closed to new replies.
5799
