December 24, 2020 at 6:39 am
nitishsharma
SubscriberDecember 30, 2020 at 12:59 amkamyarkeikhosravy
Ansys EmployeeHi,Best way to work with workbench is to start from workbench. that means in workBench you can insert a Maxwell component and after opening the Maxwell component from WorkBench you can add more design within the Maxwell. now when you close the Maxwell it will update the workbench project as well. nbtw, why are you trying to import the Maxwell project into workbench?.nJanuary 11, 2021 at 10:08 amnitishsharma
Subscriberi was already working on project which i saved ,so want to open it agaiViewing 2 reply threads- The topic ‘i saved one project “induction machine1” in Ansys Electronics desktop’ is closed to new replies.
6024
