TAGGED: ansys-design-modeler, no-separation, surface, surface-contact
January 8, 2026 at 1:44 pm
afroditi.chalkopoulou
SubscriberHow it is right now:
I cannot seem to be able to separate the two surfaces that share the common edge and make them 2 different bodies (as shown in the second picture). That probably ruins the meshing process later on.Â
I created different sketches for each rectangular and drew the same edge twice but when I tried to turn them into surfaces the shape become one. When I did one sketch and tried to separate them through Boolean or FaceSplit, they kept appearing as one body - one part. -
January 8, 2026 at 2:36 pm
Forum ModeratorEach sketch would be a separate surface. You then create a multibody part before moving to Meshing. Make sure to create as Frozen.Â
1587
1386
1242
