June 3, 2024 at 9:20 am
JooJaehoon
SubscriberI'm conducting structural analysis about break-away.
I'm predicting stress profile of gasket when frictional force applied against operating pressure like bottom schematic (a)
Stress result showed at schematic (b)
Q1. Is tendency violence occuring point (blacke circled) (inflection occured at stress contour) considered as stress concentration point or singularity point?
Q2. By applying alternative gasket shape and operating pressure, I can make same stress contour at original condition with alternative shape like schematic (c). Then, predicted tendency violence occuring pointed can be located at out of observing area, as a result, I can get stress contour with no stress concentration or singularity. As seen from above, negating stress concentration of singulairty method is valid?
June 3, 2024 at 9:41 am
ErKo
Ansys EmployeeÂ
Hi
Yes there seems to be a singularity there (you can verify it by doing a mesh study).
Perhaps try as you suggest, but I do not know if that will completely resolve this.
In most cases one can refine the mesh and look away from that singular corner and one will see that the stresses are ok some elements away from there (stress singularity).
See this article for some guidance – hope this helps.
http://www.acin.net/2015/06/02/stress-singularities-stress-concentrations-and-mesh-convergence/Â
June 4, 2024 at 12:06 am
JooJaehoon
SubscriberHigh erik, thank you for replying my question
I've checked an article you send me. It give me a good inspiration.
- The topic ‘I have question about stress concentration or singularity’ is closed to new replies.
6745
1324
1067
