February 17, 2022 at 7:16 pm
claudiokid2001
SubscriberI have a 4k resolution laptop and i had to the change the dpi setting in order to fix the scaling issue. Even though the workbench now is fine and ready to be used, when i double click on Model and the mechanical app opens some of the buttons seems to be hidden by a blue rectangle and the words become thick, black and blurry. It is not a huge problem but it honestly bothers me a bit. Thank you for the patience and the time for responding. Im an italian mechanical engineering student in my 2nd year of studying, sorry if i did not explain the issue well, but i hope the images will fill my mediocre english.
February 21, 2022 at 2:09 pmGeorge Karnos
Ansys EmployeeIf 4K Display is being used , try the following:
1.Change the High DPI settings under compatibility settings." Properties of workbench > Compatibility > Click on Override high DPI scaling "
2. Change the "Scaling performed by" option to "System(Enhanced)"
February 21, 2022 at 2:53 pmclaudiokid2001
SubscriberThank you for the answer. I have already done these steps in order to fix the main issue i had due to my 4k resolution disply. I tried to set the same dpi settings for both workbench and mechanical apps but I still have the same problem which i described and showed on my first question post at the top of this page.
Viewing 2 reply threads- The topic ‘I have an issue with the display when i open mechanical’ is closed to new replies.
4167
1487
1338
1171
