I cant use ACP (Post) Results
    • Mare Levin
      Hi, could you please help me, i created a model in APDL and use it as an external model in Workbench for static analysis, i want to use ACP (Post) but i cant drag the Solution=>Static Structural to Results=>ACP Post
    • Sampat Kumar
      Hi Mare,
      Please see the related forum thread that I attached and let me know if it helps or not.
      /forum/forums/topic/cannot-connect-my-solution-from-static-structure-to-acp-post/
      Sampat
    • Mare Levin
      Thank you for your reply, the problem is i don’t have a pre ACP, i used a external model from APDL, when i drag and drop the pre post (picture 1) i got (picture 2) and after connecting setup to model (picture 3), im not able to connect the solution to results
  • The topic ‘I cant use ACP (Post) Results’ is closed to new replies.
