LS Dyna
LS Dyna
I am encountering an error when simulating LS-Dyna in LS-Run. It gets terminated instantly.
    • YashIITD
    • Aniket
      Ansys staff can not download any files on the forum, so if you want to reach a larger audience to get answers from, please insert inline images describing your problem.
      -Aniket
    • YashIITD
      Thank you for your reply. Although I have found the problem. While giving the file path in LS-Run, there were spaces in the name of a folder, so actually it was not reading the file at all. Solving this, it worked fine.
    • igandiko
      If there are spaces, adding the path in quotes should help too.
    • YashIITD
      Quotes didn't help. Instead it didn't even run. It said 'input file does not exist'.
    • igandiko
      Thanks, good to know, looks like quotes help only with solver path, which ls-run adds by default, not the input file path.
    • YashIITD
      Yeah. Thanks anyway for your idea.
Viewing 6 reply threads
  • The topic ‘I am encountering an error when simulating LS-Dyna in LS-Run. It gets terminated instantly.’ is closed to new replies.
