TAGGED: explicit-dynamics, structural-mechanics, structure, workbench
November 26, 2020 at 3:21 am
Yspartan
SubscriberNovember 28, 2020 at 3:12 ampeteroznewman
SubscriberArray
The incompressibility parameter D1 = 2/K where K = Bulk Modulus.
/forum/discussion/4867/calculating-incompressibility-parameter-for-ogden-material-model
November 28, 2020 at 8:25 pmYspartan
SubscriberArray Thank you for your reply. I am using Mooney Rvlin 5 parameter, and this is the material https://docs.carbon3d.com/files/technical-data-sheets/tds_103208-00-e_epu-40.pdf . Will the equation you mentioned above will still work for Mooney Rvlin? Also what exactly is incompressibility factor? Tried to research online couldn't find a satisfying explanation. As you might see the only available properties for this material are elongation and corresponding stress values. However, in an impact test the material will undergo sudden compression. Do you believe these properties can be used still for the impact test ? I am inputting them in uniaxial test data for the material and then applying Mooney rvlin. If you want I can attach a zip of my simple setup.
Regards
Y.S
November 29, 2020 at 12:38 ampeteroznewman
SubscriberArray
Yes, the equation is the same. Here is the Wiki page on Bulk Modulus. https://en.wikipedia.org/wiki/Bulk_modulus
I see in the pdf file you link to there is a Stress-Strain curve for a Tensile Test. You could digitize that data and use it in curve fitting for Money Rivlin.
November 29, 2020 at 5:23 ampeteroznewman
SubscriberArray
Yes, that is the same equation for Money-Rivlin. Here is the Wikipedia entry... https://en.wikipedia.org/wiki/Bulk_modulus
In the PDF link is a graph of the uniaxial test data. You can digitize that graph and do some curve fitting in the material model to come up with coefficients for the material model.
It would be ideal if your simulation involves compression to get compression test data, but if all you have is uniaxial tensile data, that is all you have.
Materials behave differently at high strain rates that are found in impact events. Ideally, you would get rate dependent material properties, but if all you have is quasi-static material properties, that is all you have.
It really comes down to how important is the event you have to simulate and what resources you can bring to bear on the problem. If your resources are limited and the event is not too critical, then you use what you have. If you have the time and money to get proper material test data and the event you are trying to simulate is critical, then you get the proper test data.
July 12, 2021 at 5:01 pmYspartan
Subscriber.Thanks peteroznewman for this insight.
.Viewing 5 reply threads- The topic ‘HYPERELASTIC MATERIALS INCOMPRESSEBILITY FACTOR D1’ is closed to new replies.
