December 2, 2019 at 10:09 am
alexandre.gomes
SubscriberHi everyone,
i am trying to insert a load combination of self weight and hydrostatic pressure on a dam.
Is it possible to change the load step of the hydristatic pressure in order to apply it after the self weight?
In bottom right corner i have the Tabular Data but i can't change the load step.
Thanks.
December 2, 2019 at 12:13 pm
peteroznewman
SubscriberCan you make the acceleration 0 in the steps when you don't want any hydrostatic pressure?
Another way is to Deactivate the load in the steps when you don't want it active.
Are you going to add a hydrostatic pressure to the side walls as well as the dam?
December 2, 2019 at 12:36 pm
alexandre.gomes
SubscriberHi Peter,
Thank you for your reply.
No I can´t edit the Tabular data.
Can you explain to me how to deactivate the load in the steps, that would be my best option.
Yes I will have to apply the load to the side walls that are simulating the foundation of the dam.
Thank you veru much!
December 2, 2019 at 9:07 pm
December 3, 2019 at 9:49 am
alexandre.gomes
SubscriberThnaks it worked just fine!
I've been trying to export the results using apdl commands, the displacements work well, however the stresses don't.
is it possible to export the stress results of the elements to a output file?
I have used the following apdl commends:
/Output, PH_stress, txt, ,
PRESOL,S
/Output
/Output, PH_disp, txt, ,
PRNSOL,U
/Output
Again thank you so much for your help!!
December 3, 2019 at 12:13 pm
peteroznewman
SubscriberRight click on the Stress result and choose Export...
If your question has been answered, please click the Is Solution link to mark this discussion Solved, or ask a followup question.
December 3, 2019 at 12:15 pm
alexandre.gomes
SubscriberThanks.
- The topic ‘Hydrostatic pressure load step’ is closed to new replies.
6535
1311
