Hydrodynamic coefficients in controlled forward speed
    • w.s.syafruddin2
      Hi everyone,
      I'm running my simulation in the hydrodynamic response module, using an external force to govern the forward speed.
      The .dat file from the hydrodynamic diffraction module was generated with zero forward speed so that I can control the desired forward speed externally.
      Would the hydrodynamic coefficients correspond to the forward speed controlled by the external force, or would they remain based on the .dat file generated at zero forward speed?
      Thank you
Viewing 0 reply threads
