May 30, 2024 at 10:15 am
Harikrishnan K
SubscriberI am doind steady state simulation. While submitting the job in cluster, the jou file is not read properly and not running (shows error as highlighted below) but if i type on TUI window in local system, it is executing. please help me resolve this issue. The jou file,
/file/cff-files? no
/file/read-case somecasefile.cas
/file/auto-save/root-name "name"Â
/solve/initialize/hyb-initialization ok
/solve/iter 15000
/file/write-case-data name
/exit yesThe error in fluent out is
Reading "somecasefile.cas"...
Buffering for file scan...
(reads the elements)
Warning: the rp-transition-model option is not available in this solver
> /solve/initialize/hyb-initialization invalid command [hyb-initialization]
ok> /solve/iter 15000
invalid command [15000]Warning: An error or interrupt occurred while reading the journal file.
Some commands may not have been completed.
> Halting due to end of file on input. -
July 26, 2024 at 6:47 am
Luca B.
Forum ModeratorThe warning "the rp-transition-model option is not available in this solver" indicates that the transition model you are trying to use is not supported by the solver you have selected in Ansys. This could be due to a mismatch between the features available in the solver and the requirements of the transition model.
What Fluent solver are you using?Â
How do you run your simulation with the cluster? I suggest you to try saving in local one dat file and restart from this one.
Luca
- The topic ‘hpc cluster shows error in journal file’ is closed to new replies.
