February 11, 2019 at 3:03 am
kzqing
SubscriberHello. I am simulating hypersonic flow with finite rate chemistry using Fluent. As both thermal and chemical nonequilibrium exist, I think I need to include vibration temperature for the reaction rate. As Fluent only considers the translational temperature, a UDS is needed for vibration temperature. I also need to use DEFINE_VR_RATE to define the reaction rate. There is a argument in DEFINE_VR_RATE: Reaction *r. It is the pointer to data structure that represents the current reaction. From the example in udf manual, I saw that we can access some data using r, such as r->n_reactants, r->A, r->E, r->b. Are these what we input in the reaction panel for the Arrhenius Rate? If I want to include third-body efficiencies and backward reaction, what variables can I use in my DEFINE_VR_RATE udf? Thank you.
February 11, 2019 at 8:49 am
DrAmine
Ansys Employee1/Yes: That is your input from GUI.
2/Are not documented.
February 11, 2019 at 3:30 pm
kzqing
SubscriberHello Amine,
Do you know where I can find the documented variables related to the reaction?
Thanks,
Qing
February 11, 2019 at 3:47 pm
DrAmine
Ansys EmployeeIn the customization manual. Any other else is not supported (..but you can check the header files where you might find more on the reaction structure)
February 11, 2019 at 5:38 pm
kzqing
I didn't find any other descriptions about reaction structure, but I have other questions.Â
The molar rate of creation/destruction of species i in reaction r is given byÂ
The net source of chemical species i due to reaction is computed as the sum of the reaction sources over the NR reactions that the species participate in:
(1) In DEFINE_VR_RATE( name,c,t,r,mw,yi,rr,rr_t), we need to give reaction rate to rr and rr_t. What values should we give them? Is it equation (a) or equation (b)?
(2) If I want to include third body efficiencies and backward reactions, I need to specifically defineÂ
in equation (a) and use them for rr and rr_t, right?
(3) What name can I use in udf if I want to access stoichiometric coefficient for reaction i/product i in reaction r that are input from GUI?
Thanks,
Qing
February 11, 2019 at 8:22 pm
DrAmine
Ansys EmployeeDEFINE_VR_RATE calculates the reaction rate of each reaction before appliying getting multiplied with the coefficients. It just provides the rate of the reaction kgmol/m^3*s. When it is multiplied by the respective stoichiometric coefficients, yield the production/consumption rates of the individual chemical components.Â
Again if accessing stochiometric coefficient is not documented in the manual then is not supported. You can however look into the header files and search for reaction strcuture whe you might perhaps find how to access.
February 12, 2019 at 6:00 am
DrAmine
Ansys EmployeeYou can get started by r->stoich_reactant
- The topic ‘how to write volumetric reaction rate in udf’ is closed to new replies.
5834
