October 24, 2024 at 11:36 am
Ender
SubscriberHi,
Our company use the ansys apps, we need to configure lmborrow feature, how to activate that,Mostly using ANSYS 2024 R1, also we have borrowable license, how to set,Which is a suitable version of licensing tools? Where can I download?command "lmutil borrow x xx-xx-xx xx:xx" doesn't work as we accepted,It assigns to the environment variable, but the use of borrow is not visible in the lmstat results. -
October 25, 2024 at 12:59 pm
Rajeshwari Jadhav
Forum ModeratorHi,
You need to have borrowable keyword in your license file, you can find it under licensing portal.
If you are a commerical user please raise your technical requests through the new ACSS.
If you are not a registered user or a first-time user, Register to ACSS.
1885
1404
1303
