October 10, 2023 at 2:21 pm
October 10, 2023 at 3:03 pm
ErKo
Ansys EmployeeÂ
Hi
First it needs to be used with MSUP (mode super pos.) analysis (say harmonic), so place the command snippet there in the harmonic analysis (not under the modal).
I would try to look at MDAMP in the help apdl command reference guide.
Also try MDAMP,1,0.1,0.1,0.1 to see if the first ~ 1-3 peak go down.
All the best
Erik
October 11, 2023 at 5:02 am
chonkiat.lee
SubscriberThanks Erik.Â
I am using MSUP for random vibration. I can see the peak will go down... however, I want to make the second peak amplitude going up by changing to very small damping ratio. I notice that we can dampen the peak but only able to increase the peak slightly even we use very small value of damping ratio.
Do we need to use global damping ratio when we use mdamp? -
October 11, 2023 at 8:38 am
ErKo
Ansys EmployeeHi
See the help manual on all different forms of damping.
If you are not able to open the links, refer to this forum discussion:Â How to access the ANSYS Online Help
Hope that helps
Erik
- The topic ‘How to use MDAMP’ is closed to new replies.
5814
