Embedded Software
Embedded Software
Topics related to SCADE Suite, SCADE Display, SCADE One and more.
How to use `$@$` as input operator of iterator(e.g. map)?
    • fdtsaid
      Some predefined operator can be used as input operator of iterator. Such as the following example
      function test(a,b: int8 ^ 3) returns (c: int8 ^ 3)
        c = (map $+$ << 3 >>) (a, b);
      But I am trying to figure out how to use $@$ as input operator correctly. In the following program:
      function mapOp(arr1,arr2: int8 ^ 2 ^ 3) returns (oarr: int8 ^ 4 ^ 3)
      let
        oarr = (map $@$ <<3>>) (arr1,arr2);
      tel
      The intention of the above program is to concatenate each element of type int8^2 in arr1 and arr2 to value of type int8^4. But I got the following error:
      Prefix operator $@$ expects 2 size parameters but is here used with 0
      How to use $@$ as input operator of iterator in a correct way?
Viewing 0 reply threads
