TAGGED: ansys-mechanical, ansys-student, apdl, mechanical-apdl, structural
November 24, 2021 at 10:49 pm
jgrani6
SubscriberHello, I am trying to model a thin walled pressure vessel using axisymmetric option for solid element. I have a set of lines which draw the outer edge. I've done it with shell elements easily, I now want to model it using Solid 182 elements using axisymmetric option. However, I need to mesh area for plane elements. How do I add thickness to my lines so that instead of lines, I have 2d areas that still draw the outer edge?
Thanks
November 24, 2021 at 11:09 pmjgrani6
SubscriberThis is in Mechanical APDL
December 1, 2021 at 11:33 pmwrbulat
Ansys EmployeePlease try this test case I created then see if you can apply this strategy to your model:
fini
/cle
/vie,1,1,1,1
/pnu,kp,1
C*** PARAMETERS
r=0.5 ! END RADIUS
l=1 ! LENGTH OF STRAIGHT SECTION BETWEEN SPHERICAL ENDS
t=0.10 ! PRESSURE VESSEL WALL THICKNESS
C*** PRESSURE VESSEL EXTERNAL SURFACE
/prep7
wpcs,-1,0
wpof,,-l/2
cswp,11,1
k,1,r,-90
k,2,r,0
l,1,2
wpof,,l
cswp,12,1
k,3,r
k,4,r,90
l,3,4
csys
l,2,3
lplo
/wait,2
C*** CREATE AREA REPRESENTING PRESSURE VESSEL WALL CROSS SECTION
allsel
numc,line
csys
*get,ymin,kp,,mnloc,y
*get,ymax,kp,,mxloc,y
kgen,2,kp(0,0,ymin),,,0,0,t,500
l,kp(0,0,ymin),kp(0,0,ymin)+500
*get,lmax,line,,num,max
adrag,all,,,,,,lmax
aoff,all,-t,1000
lsel,s,loc,z
asel,none
l,kp(0,ymin,0),kp(0,ymin,0)+1000
l,kp(0,ymax,0),kp(0,ymax,0)+1000
al,all
cm,keep_a,area
cm,keep_l,line
alls
cmse,u,keep_a
cmse,u,keep_l
adel,all,,,1
ldel,all,,,1
alls
aplo
Best Bill
Viewing 2 reply threads- The topic ‘How to turn a line into a thin 2D area?’ is closed to new replies.
3862
1414
1221
1118
1015
