March 11, 2020 at 11:42 pm
alexhathway
SubscriberIs There A Provision To Copy/ Transfer Material Properties (Piecewise Linear) For Different Geometries ?
Its Very Annoying To Manual Add All the Data Again and again for different geometries using Piecewise Linear, adding 50*4 = 200 Points Again and again is Difficult.
REGARDS
March 12, 2020 at 3:03 am
Keyur Kanade
Ansys EmployeeYou may want to use journal file. The journal file uses text user interface commands. Please explore TUI commands. Please go through documentation.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
March 19, 2020 at 11:25 pm
alexhathway
SubscriberSir,
Can You Please Help me with The Commands to Add Properties via Piecewise Linear (Without Manually Adding each)?
REGARDS
March 20, 2020 at 4:59 pm
Karthik Remella
AdministratorHello,
Unfortunately, we do not help write customizable scripts as part of support here on the community. Having said that, we will be able to point you to resources or provide pointers in case you are having issues with running/debugging your scripts.
As my colleague recommended, please go through the documentation as well as the TUI commands to write your journal file.
Thank you.
Best Regards,
Karthik
March 24, 2020 at 8:16 pm
alexhathway
SubscriberSir, I have Already Added Material Properties, But i Want same set of variable properties for different geometries ??
March 25, 2020 at 2:46 am
Karthik Remella
AdministratorHello,
I'm really glad that you have already written your code for the properties. Have you tried the User-Defined Database under Material Properties?
Thanks.
Best Regards,
Karthik
March 25, 2020 at 7:42 pm
alexhathway
SubscriberNo! I am not familiar With It sir.. I will Try To Explore
Thank You
- The topic ‘How to Transfer Material Properties (Piecewise Linear) For Different Geometries ?’ is closed to new replies.
6660
1313
