June 11, 2021 at 8:45 pm
ba_pansiot
SubscriberHello, I am trying to update a large APDL code and switch from SOLID69 to SOLID226 for a thermal electrical simulation. The code is running and I obtain a result. However, the results are quite different from the one with SOLID69. What could cause this considering that all other parameters are being the same?
Thankyou.
June 14, 2021 at 5:03 pmAniket Chavan
Forum ModeratorHave you set the KEYOPT(1)=110?
-Aniket
June 14, 2021 at 5:28 pmba_pansiot
SubscriberYes. Also, the mesh parameters are kept the same as well as solver parameters.
Viewing 2 reply threads- The topic ‘How to switch from SOLID69 to SOLID226for thermal electrical analysis ?’ is closed to new replies.
6189
