August 30, 2024 at 3:50 pm
Mehdi Baghaee
SubscriberIn APDL, If A and B are two arrays with the same dimentions, how is it possible to simply substitute the entire value of B in A without substituing one by one (using DO loop)?
A=B , *SET, A, B and *VOPER, A, EQ, B produces error (Parameter A needs subscripts).
September 13, 2024 at 12:29 pm
Ashish Khemka
Forum ModeratorHi Mehdi,
In APDL (ANSYS Parametric Design Language), you can substitute the entire value of one array into another without using a DO loop by using the
*VOPERcommand. This command allows you to perform vector operations on entire arrays. Here’s how you can do it:*VOPER, A, B, COPYThis command will copy all the values from array
Binto arrayAin one step, assuming both arrays have the same dimensions.Regards,
Ashish Khemka
