TAGGED: ansys-fluent, explicit-dynamics, fluent, fluid-dynamics, multiphase
October 8, 2021 at 10:11 am
Sliceee123
SubscriberIt's not possible to edit STL geometry , then how we can give Boundary conditions For the Complex STL geometry.
October 8, 2021 at 1:17 pmRK
Ansys EmployeeHello,
I would suggest you to either wrap it or convert it to a solid and then apply BC. Again, this depends on the number of facets you have in the model and how intricate your model is.
October 19, 2021 at 2:40 amSliceee123
SubscriberModel is complex , Is there any better way to do so ..?
October 19, 2021 at 10:16 amRob
Forum ModeratorHow many surfaces do you need? Is the stl one big file or is it made up of multiple bits?
October 26, 2021 at 1:31 pmSliceee123
SubscriberIt is one STL file , but the structure is complex .
October 26, 2021 at 1:39 pmRob
Forum ModeratorAre the surfaces you want to split flat? Ie can you use a seed & angle on the surface facets?
October 26, 2021 at 1:47 pmSliceee123
SubscriberActually I want to do nasal airflow simulation , no surfaces are not flat
October 26, 2021 at 2:30 pmRob
Forum ModeratorIn which case can you do some of the separation in the segmentation tool?
October 26, 2021 at 4:48 pmSliceee123
SubscriberSegmentation tool in Ansys?
October 27, 2021 at 10:28 amRob
Forum ModeratorFluent Meshing allows surfaces to be split from a seed. I'd get a mesh first though. Otherwise the software that's used to convert from DICOM to stl usually has some very good capping tools.
Viewing 9 reply threads- The topic ‘How to Split STL geometry for giving boundary conditions?’ is closed to new replies.
6189
