August 28, 2021 at 10:51 pm
SC1
SubscriberAfter importing an NX CAD file into Workbench, I tried to open Spaceclaim but got the error "Unable to import the specified geometry into SpaceClaim". SpaceClaim closes afterward. I am working on Ansys 19.2.
August 29, 2021 at 3:02 pmpeteroznewman
SubscriberTry exporting a Parasolid from NX. Use an older Parasolid Version that it is compatible with ANSYS 19.2.
Try to open that with SpaceClaim.
If that doesn't work, in Workbench, add a Geometry cell, open DesignModeler and use the File, Import External CAD Geometry menu item to import the Parasolid File.
If that is successful, close DM and the right click on that cell and Edit with SpaceClaim.
August 31, 2021 at 12:57 amSC1
SubscriberI need to import the file as .prt because I need the parametrization that was created on NX.
September 5, 2021 at 1:08 pmpeteroznewman
SubscriberI assume you have the ANSYS NX CAD Interface License. That is what you need to have in order to use the parameters in NX for simulation in Workbench/Mechanical. If you have that license, you don't ever open the geometry in SpaceClaim, you must only use NX to edit the geometry and when you do, Workbench will update the geometry.
April 19, 2022 at 12:45 pmabraham.irias
Peter, I am facing a somewhat related issue. I have NX (Siemens 1980) and the ANSYS NX CAD interface license (2021 R2). I typically import my geometry from NX and make any model simplifications directly in NX. However, NX does not have a feature like "Share Topology" and thus I want to be able to import my geometry into SpaceClaim and make the slight change but still hold the associativity back to NX.
I am having a hard time finding a way to Update Geometry from NX once my model has been edited in SpaceClaim. I would imagine that there would be a feature in Spaceclaim to update the geometry from NX so it still holds all the associativity for things like parameters/named selections. I found a way to do this update in DM.
April 20, 2022 at 3:14 ampeteroznewman
SubscriberI suggest you stick with DM to bring NX geometry in with parameters and add Shared Topology.
Viewing 5 reply threads- The topic ‘How to solve: “Unable to import the specified geometry into SpaceClaim”?’ is closed to new replies.
6625
1311
