August 5, 2020 at 12:34 am
jil260
SubscriberHi,
My project is a water entry problem as seen in the attachments. I want the pressure contour plot of water volume only like the third picture. But, traditionally, the contour plot can only show one characteristic one time. Thanks in advance.
August 5, 2020 at 12:58 amAugust 7, 2020 at 3:08 amAugust 7, 2020 at 12:48 pmAmine Ben Hadj Ali
Ansys EmployeeMy colleague was showing the way to do in Fluent. To avoid any misunderstanding you need to provide the software you are using when raising the question.In CFD-Post: same can be done and that is the right option. You just now need to provide the range to which the field should be clipped. For now it is using the default global range.nViewing 3 reply threads- The topic ‘How to show volume fraction and pressure at the same time in Fluent Postprocessing’ is closed to new replies.
4803
1582
1386
1242
