March 1, 2024 at 8:13 pm
javat33489
SubscriberHi all.
I consider 1/4 test part in LS-Dyna ACT Workbench.
The model is a cylinder and it stands on a plane.
The calculation involves two loads: first, a force presses on the cylinder from above, then the cylinder shifts.
The problem is that if I apply a shift to the cylinder, due to symmetry it is placed on all 4 sides. And the result is compression, but the complete part does not fit in.Â
How to shift the entire cylinder?
March 1, 2024 at 10:05 pm
peteroznewman
SubscriberYou can only use symmetry when both the geometry AND the loads are symmetric. In this case, the load is only symmetric about one plane but not the other. Use 1/2 symmetry instead of 1/4 symmetry for this analysis.
March 3, 2024 at 4:34 am
javat33489
SubscriberThanks for your answer sir! Tell me, does this answer only apply to Ls-Daina AST? Or is this also for other modules (static, transient, etc.)?
March 3, 2024 at 10:45 am
peteroznewman
SubscriberIt applies to all types of analyses.
- The topic ‘How to shift the entire cylinder?’ is closed to new replies.
5664
1890
1419
1304
