Optics
Optics
Topics related to Speos.
How to set up Ansys License Utility
    • Zhizhong Yan
      I tried to use default settings, but Zemax Does not run at all.
      -------------------------------------------- NORMAL STARTUP 2023/09/12 12:41:07 ---------------------------------------------
      Ansys Licensing Interconnect version 2023.2.0 (20230523) for winx64.  Updated at Ansys Release 2023 R2.  Started on 2023/09/12 12:41:07 by Zhizhong@DESKTOP-HTEIL2O:winx64 with pid 9140.
      (C) 2023 ANSYS, Inc.  Unauthorized use, distribution, or duplication is prohibited.
      Built Using FlexNet Publisher v11.16.4.0 build 252457 x64_n6
      Built Using OpenSSL 1.1.1t  7 Feb 2023
      Please note that entries in this debug log have the following format:
      TIMESTAMP              ACTION              FEATURE                    REVISION (BUILD DATE)             A/B/C/D                 W/X/Y/Z   PID:MPID:APP:USER@HOST:PLATFORM:DISPLAY                                    SOCKET:IP
      Licenses statistics:
      A is the number of licenses requested by this ACTION.
      B is the number of licenses used by this USER.
      C is the number of licenses used by all users.
      D is the number of licenses available in the local license pool.
      License server performance statistics:
      W is the number of currently connected client applications.
      X is the maximum number of connected client applications.
      Y is the unique serial number of this client application.
      Z is the number of all client applications served by this Licensing Interconnect server.
      2023/09/12 12:41:07    INFO                ANSYSLI_CMD=C:\Program Files\Ansys Zemax OpticStudio 2023 R2.01\licensingclient\winx64\ansyscl.exe -acl DESKTOP-HTEIL2O_Zhizhong -nodaemon -log C:\Users\Zhizhong\AppData\Local\Temp\.ansys\ansyscl.DESKTOP-HTEIL2O.DESKTOP-HTEIL2O_Zhizhong.log
      2023/09/12 12:41:07    INFO                ANSYSLI_INITIALIZATION_FILE=No initialization file found.
      2023/09/12 12:41:07    INFO                ANSYSLI_PRODORD_FILE=COULD NOT BE FOUND!
      2023/09/12 12:41:07    INFO                ANSYSLI_TIMEOUT_FLEXLM=15
      2023/09/12 12:41:07    INFO                Configuring ACL Core
      2023/09/12 12:41:07    INFO                ACL Core Initialized
      2023/09/12 12:41:07    INFO                ANSYSCL_PORT=63173
      2023/09/12 12:41:07    INFO                Listen Socket Created
      2023/09/12 12:41:07    INFO                ANSYSLI_CLIENT_IDLE_TIMEOUT=30
      2023/09/12 12:41:07    INFO                ANSYSCL_FNP_PATH=1055@localhost
      2023/09/12 12:41:07    INFO                Ready to accept connections.
      2023/09/12 12:41:08    INFO                ANSYSLI_IP_OVERRIDE option is off.
      2023/09/12 12:41:12    CLIENT_ACCEPT        1/1/1/1        6940:127.0.0.1
      2023/09/12 12:41:12    CLIENT_CONNECT        1/1/1/1   12940:12940:ANSYS OPTICSTUDIO:Zhizhong@DESKTOP-HTEIL2O:winx64              6940:127.0.0.1
      2023/09/12 12:41:12    INFO                Shared features for User/Host/Display context with id DESKTOP-HTEIL2O_Zhizhong:
      -1   zos_level1                      -1   zos_level2                      -1   zos_level3
      2023/09/12 12:41:12    NOTICE              User/Host/Display context created with id DESKTOP-HTEIL2O_Zhizhong.                  1/1/1/1   12940:12940:ANSYS OPTICSTUDIO:Zhizhong@DESKTOP-HTEIL2O:winx64
      2023/09/12 12:41:16    INFO                Unable to connect to FLEXlm path 1055@localhost; adding to "Unavailable FLEXlm Servers" cache.
      2023/09/12 12:41:21    DENIED              zos_level2                      23.2 (2023.0505)             1/0/0/0                 1/1/1/1   12940:12940:ANSYS OPTICSTUDIO:Zhizhong@DESKTOP-HTEIL2O:winx64              6940:127.0.0.1
      Request name zos_level2 does not exist in the licensing pool.
      Cannot connect to license server system.
      The license server manager (lmgrd) has not been started yet,
      the wrong port@host or license file is being used, or the
      port or hostname in the license file has been changed.
      Feature:       zos_level2
      Server name:   127.0.0.1
      License path:  1055@localhost;
      FlexNet Licensing error:-15,10.  System Error: 10061 "WinSock: Connection refused"
    • Lito
      I believe this is a duplicate to post, Zemax can’t start (ansys.com), which has been resolved. Kindly mark both posts as answered/resolved. Thank you!
  • The topic ‘How to set up Ansys License Utility’ is closed to new replies.
