How to set pre-loading?
    • jumpei
      Assuming that there are three mass points(called A, B, C), I want to adjust the displacement of B after fixing A (pre-loading),
      and then fixing C, and then adjusting the displacement of B again.
      How to set this progress?
    • SSURA
      Hello Jumpei,
      You can approach the problem in many ways, two of the simple ways can be as follows -
      Hope this helps!
      Thanks,
      Sahil
      For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
      If you are not able to open the links, refer to this forum discussion: How to access the ANSYS Online Help
  • The topic ‘How to set pre-loading?’ is closed to new replies.
