May 8, 2024 at 3:32 pm
limeng xu
SubscriberThe conductivity of the material is set to change with temperature under the solver of the DC conduction. To verify the change in conductivity set up the following extreme case: set up the material as an insulator, but at a temperature greater than 0, the material is a conductor. At the same time, the temperature of the material is set to 30 degrees. However, the electric field distribution calculation results are still distributed according to the case where the material is an insulator.
May 22, 2024 at 1:48 pm
HDLI
Ansys EmployeeHello Limeng,
   Please make conductivty < 1, like 0.8, in the material propertie and also check material thresdholds in design setting to make sure what is the conductivity of insulator. Thanks.
HDLIÂ Â Â
- The topic ‘How to set material conductivity to change with temperature in Maxwell?’ is closed to new replies.
