August 21, 2023 at 8:31 pm
Ashwini Kumar
Ansys EmployeeGenerally speaking, the license information should be entered during the VM creation. The following procedure is the same for the following versions: Ansys License Settings 2023 R1, Ansys License Settings 2023 R2.
If this is not done, you need to point to the correct IP address to use the Ansys application.
Windows: Start -> Ansys 2023R1 -> Ansys License Settings 2023 R1
Linux:
On the command prompt, navigate to /NFS_Storage/ansys_inc/shared_files/licensing
in order to edit ansyslmd.ini, you need to know the SSH password. See the instructions on how to get SSH
You can edit the ansyslmd.ini and save it.
Viewing 0 reply threads
- The topic ‘How to set license information in the VM’ is closed to new replies.
1890
1419
