August 19, 2024 at 4:14 am
Mehdi Baghaee
SubscriberI am try to select some special areas by their numbers (e.g. 2,4,9,11,12,13,22,99,111) using ASEL command (not GUI) in apdl.Â
Does anybody know how is it possible in APDL ?
August 19, 2024 at 9:11 am
Deepak
Ansys EmployeeHi,
ASEL: Selects a subset of areas. Using this u can select the area by their numbers.
ASEL,S,AREA,,2,     #Select a new set with area no. 2
ASEL,A,AREA,,4,9,5Â Â Â #Additionally select a set, with areas for 4 to 9 at an increment of 5 (i.e., area no. 4 and 9) to the current set
ASEL,A,AREA,11,13,  #Additionally select a set, with areas for 11 to 12 at an increment of 1 (i.e., area no.11,12,13) to the current set
..................................  # You can select the remaining areas.
APLOT,             # Plots the current area selection set in the graphic window.
Using the CM command you can give a component name (named selection) to the current selection.
Refer: ASEL (ansys.com) | CM (ansys.com)
Thanks
Deepak
6790
1332
1152
