January 8, 2020 at 4:18 pm
Puneeth
SubscriberI am new to ANSYS and I was unable to find how to do this 'select geometry' and 'select mesh' operation in the R2 version. What does the operation [Update selected parts-> Update: Use geometry parameter values] do and how to undo it if I selected it by mistake. Can someone please give me an answer asap. Thanks in advance.
January 9, 2020 at 12:13 am
peteroznewman
SubscriberPlease reply and insert an image of where you are when you see this message.
What are you trying to do when you want to 'select geometry' and 'select mesh'? There are geometry filters such as point, edge, face and body that can select geometry based on the filter setting and if there is a mesh, there are filters for node, element face, element for selecting FE entities. Is that what you mean?
January 16, 2021 at 5:01 pm
December 2, 2022 at 10:45 pm
- The topic ‘How to select ‘select mesh’ and select geometry’ in latest R2 version’ is closed to new replies.
5834
