May 17, 2025 at 9:54 am
Md. Abdur Rahman Dip
SubscriberHow to select linear or quadratic element order in Ansys Fluent in Workbench 2024 R2?
Thank you
May 18, 2025 at 7:23 pm
peteroznewman
SubscriberElements for Fluent must be linear. If you mesh in Fluent Meshing, there is nothing to select, it will only create linear elements. If you mesh in the Ansys Mesh component, in the Details of Mesh, the Physics Preference defaults to Mechanical and Element Order to Program Controlled. Change the Physics Preference to CFD. The Element Order setting will disappear and it will create linear elements for Fluent.
May 20, 2025 at 8:51 pm
SubscriberThank you.
Ansys Innovation Space
1057
1051
896
877
